Has anyone seen the CrawlTek highline fenders on a Tj/Lj with less than 40” tires. I’m curious how they look with 35”-37” tires as I’m interested in them but can’t seem to locate pictures of them on anything under 40”s.
Thanks
Thanks
So does Metalcloak, I hear...TnT let’s you run 35’s no problem without cutting the hood
Use the fender at stock height for now. Then highline when you go bigger.I don’t want metal cloak. If I went TnT I’d get the highlines anyway but would prefer a lighter weight fender. As I will be on 40-42” tires eventually but for the next two years or so I’m stuck with 37” or under.
I’m removing my current tube fenders and using them on my sons Tj build and getting highlines now so I’ll be ready for when I get my full width axles completed.Use the fender at stock height for now. Then highline when you go bigger.
If you aren’t cutting the hood you’re only gaining an inch over stock, no matter what brand you run.....TnT let’s you run 35’s no problem without cutting the hood for the same $$$
Thank you. That what I was wanting to see.Here's mine when it was still sporting well worn 37's (probably like 35.5's in the photo. This is with a 4" springs and a 1.25" body lift.
Did you ever pick some highlines?Thank you. That what I was wanting to see.
Nice Jeep
Yeah I went with Aluminum Genright Highlines and inner fender kit, and matching Genright Aluminium corners and rear fenders, new Genright mini boat side sliders, and a few other Genright goodies. The Crawltec’s are really nice but never came back in stock. I have not been able to install anything yet but it’s all here.Did you ever pick some highlines?
Did you ever get these installed?Yeah I went with Aluminum Genright Highlines and inner fender kit, and matching Genright Aluminium corners and rear fenders, new Genright mini boat side sliders, and a few other Genright goodies. The Crawltec’s are really nice but never came back in stock. I have not been able to install anything yet but it’s all here.
I would get something else if you want or need flares. Check out Nemesis, their fenders have a bolt on flare option.@OldGloryLJ do you think would be any way to add flare to the Crawltek?
I look forward to seeing it.I'll have a set installed in the next several weeks, on 35s. Longer term plan is to probably go bigger but for now I'll be customizing the shock mounts do get 11s up front.
Old thread but I’m putting some crawlteks on my LJ and wondering what flares you used for the rear.
