SOS
I’m replacing the sway bar links and drivers inner tie rod end and left outer.
I want to replace the pitman arm and drag link as well since I’m having a creaking issue when turning slowly and the steering wheel is a bit loose/crooked. But not sure if this is a good idea? Or even necessary.
Also, there’s a squeal coming from the rear when driving slowly it’s like a rotational squeal that only sounds on one full rotation. Any thoughts on what this is?
