I began getting death wobble when I hit bumps at highway speeds. I replaced the front track bar which solved the death wobble, but I still got a shimmy when I hit bumps on the highway. The tires are well balanced and the Jeep does not vibrate. Based on the age of the Jeep and what I have read on this forum, I decided to replace the front control arms. I ordered a Crown front control arm kit that included both upper and lowers from Morris4X4.
Two weeks ago I replaced the lowers and immediately noticed a big improvement. The shimmy was almost completely gone. This last weekend, I replaced the uppers and noticed that the shimmy had returned and was much worse than before.
One detail that may be important. When I was torqueing the upper control arm on the driver's side, the torque wrench never clicked and I kept tightening. It didn't feel all that tight, but the control arm bolt on the axle side with the weird head snapped. I replaced it with an equivalent metric bolt and nut that fit snuggly through the bushing on the axle and the holes in the control arm.
This morning I crawled underneath it hoping that maybe I did something stupid like forgetting to tighten one of the control arm bolts, but no such luck. Everything is tight so I picked my old control arms out of the garbage. Even at 15 years old they seem to be better than the Crowns.
I'm wondering if anybody has any experience with stuff from Crown either good or bad and any ideas on what, if anything, I may have screwed up.
2002 Wrangler X, 4.0L, auto trans. This Jeep is completely stock. No body or suspension lift. Even wear on tires and drives straight.
