You won’t,once you get the correct clockspring do you know how to time it,or set it back to center?I’ll have to see if I have the wires in my steering wheel. I’ll check soon and if so just follow those
You won’t,once you get the correct clockspring do you know how to time it,or set it back to center just wait until you get the parts and show what you got
No but I’m sure I can find it. I kinda thought it was just plug and play.You won’t,once you get the correct clockspring do you know how to time it,or set it back to center?
Not plug n play,depends on what all he gives you ,read the all data schematics on the previous page from a couple years agoNo but I’m sure I can find it. I kinda thought it was just plug and play.
The only thing he will have is the battery temp wiring.he will have to run the 4 new pins to the grey pcm plugI'm still not convinced that you don't already have some of the wiring already. Just because you don't have the pigtail, doesn't mean some of it isn't already there.
From first page of this thread, look at the orange line I have highlighted on the left of the wiring diagram. That is the series of wires that runs from the clockspring (connector C2) to the PCM (V37 20 RD/LG) through connector C108.
For the run from the Clockspring to connector C108 - V37 is like the line code, "20" is the gauge of wire, "RD/LG" means its a Red and Light Green wire. C108 is a Blue connector down by where your left ankle/shin is located when driving, plugged into a gray box. The little "D10" by C108 on the diagram indicates that it is using pin location #10. Here is the pin out diagram.
Locate pin location #10, and see if there is a RD/LG wire there, and then check the other side of the connector (that would be the run from C108 to the PCM). I've found it's easy to locate one of the corners first to get my orientation down (so, find the Yellow wire with Red stripe, and that's D1, then go from there). If it's there on the backside of the connector, then it's likely already ran all the way to the PCM.
Do the same thing for the BR/YL (Brown with Yellow stripe) wire for line K167 20 BR/YL.
Not trying to sound like a jerk here, really just curious, but how can you be so sure that's all he'll have? I've found that these are all a mixed bag of what came out of the factory.The only thing he will have is the battery temp wiring.he will have to run the 4 new pins to the grey pcm plug
I thought he had an older tj,as soon as he get his parts we just need to see what all he gets, I can take pics of the wires INot trying to sound like a jerk here, really just curious, but how can you be so sure that's all he'll have? I've found that these are all a mixed bag of what came out of the factory.
NiceI’ll be home tomorrow and everything should be delivered I’ll post everything that is sent to me
Alright here we go.
Looks like a good start,what’s up with the cut wires
I’m not sure why the wires are cut. I assume it was taken out of Jeep from a junkyard but I’m not sure if those wires matter for the cruise or not
I’m not gonna mess with my pcm yet. Just gonna look at the plug that I had sent to try to understand it betterYour original plug will have to have 4 holes drilled to install the wires,if your not careful and unplug it completely from the pcm and then remove the black cover you will have to replace the plug,
