wondering if that pinion is so high, it's rotated the lower mounts out in front of the axle more than below and pulling the uppers way back. thats the only thing i could think of compressing the lower and stretching the upper link space.
Sounds like this shop specializes in "long arms". Also bet if you let him try to fix this he would tell you that you need to buy one of his long arm kits to "fix your issues". You did good taking it out of their hands. Take your time and post the pics. We can help you out here when you're ready.Game plan is that they are calling Currie this morning. If it’s not corrected after that call I will be picking up the Jeep on my way home this afternoon. This shop is top notch and experienced but they deal primarily with Clayton. Perhaps they do t have much experience with this combo.
Update: First, let me remind everyone that this is my first experience doing this and I had no real mechanical experience. Point is that I have learned most of what I know from you guys, youtube, etc. I went to the shop this afternoon. We talked over everything going on with the Jeep. The rear end pinion is set. We are nervous because the upper control arms don't have a whole lot of thread in the arm. The lowers are nearly all the way in. My next step now is to remove the Savvy Crossmember to correct the TC contacting the tub. I am hoping that will remove the vibrations and the way the Jeep sounds. Since I did the Tummy tuck she has run loud. IF that solves that issue I will then adjust the front pinion. In the meantime, I will put the new bumpers on, wire up the fog lights, and finish other odds and ends. The shop does a good job. They are more than a bolt on shop.
Agreed. At that lift height it should be slightly forward of center wheel well or at maximum centered.The track bar is probably running right into the gas tank, or the crossmember at the least.
Not picking on you or that rule but something that often piques my interest is if those rules work, then jam nuts shouldn't.Do you know how much thread engagement you have? Minimum thread engagement is Dx1.08 so IIRC the Currie uppers are .75 thread so you want at least 13/16 engagement. My real question is why the shop let your TJ out the door without addressing the tcase touching the tub? That is by far easier to take care of before you put the crossmember in and a bit of a red flag to their work QC.
Is you a betting man?While I hope the OP has resolved this, is it not possible that he received some LCA's or UCA's built on a Friday at 5? I've found that this forum defends everything Savvy and points to human error (or in this case, unintelligent shops). While I cannot comment on Savvy products, I can attest that I've had another manufacturers' UCA's short. If his LCA's are threaded all the way in, his driveshaft is a couple degrees below pinion angle, and the UCA's don't have the 13/16" minimum thread engagement, then I'm arguing that something is wrong with the kit
I wouldn't bet on it. The only way that would be true is if the diff cover is slamming hard into the front of the gas tank skid and even then I'm not sure you could make it hit.The track bar is probably running right into the gas tank, or the crossmember at the least.
If you like people now, wait until you own a business, then you will hate everyone...especially know it all's and cheap fuckers who want everything for nothing.I knew I should have started a Jeep business. It’s hard work day in and day out though.
Do you not have tools and a parking lot or space to make adjustments to your setup?People expect too much from shops. I'd drop my Jeep off in a lot of forum members garages before a shop. I've used shops a lot due to the weird constraints I have when it comes to working on my Jeep. They're good at bolting stuff up, they're not good at setting stuff up. One of the problems I've faced with my Jeep is that it has a lot of good parts bolted to it, but nothing is setup correctly just because a lot of work has been done in shops.
Can't wait to finally get a garage and out of the city in a few years
