I am going to install my new Currie control arms this week hopefully. I think it is going to be a slow go because I have to work and it is well into the 100's by now, but I have a few questions for adjustable control arm veterans.
First Is there a rule of thumb on what side the adjuster goes on the lower control arms. In the videos I see them installed on the frame side and others on the axle side. I am betting it really doesn't matter, but what do you suggest and why?
Also Is it common knowledge to just use the stock bolts on the axle side of the front uppers, because it is next to impossible to drill out. Or to I try and drill and see how far I can get to use the currie bolts?
Lastly when installing the rear uppers I have double adjustable Do I start out with them the same size as stock and install them and adjust them pretty much equally to push the top of the axle back or do I pull both the top ones and set one arm and make the other one the same size? (I know this is a matter of debate, but my factory ones are not adjustable and are virtually the same size so I think that is a good starting point)
These maybe be a lot of questions and probably should be multiple threads but I will see how this goes. I imagine once I crawl under it will also make more sense, but I just got these questions from reading the inter-webs.
I am pretty excited to get started on this project.
Thanks in advance!
Thanks in advance!
