I have a question after installing these items on my 2003 Rubicon:
Made these adjustments to the CurrectLync:
My concern is whether I should be concerned about clearance when the axle is drooped (whether one side or both). It seems like if just the right side of the axle is at full droop, then it may be ok since the sway bar bracket would be angled up with the left side of the axle, but if both sides are at full droop, then the angle of the drag link would cause the knuckle to come in contact with the sway bar bracket. This is particularly true since the Anti-Rock linkage is on the inside of the sway bar bracket.
I've read the thread on this forum about the same issue (https://wranglertjforum.com/threads/currie-currectlync-install-issue.13091/), but his issue was at ride height and proved to be related to 2" front spacers which had been installed by the PO, thus increasing the height of his lift from 4" to 6".
I admit I have a hard time imagining scenarios in which both sides of the axle are at full droop and you're trying to execute a hard right turn...but still.
A few other notes:
Thanks in advance.
- Currie 4" lift kit
- Currie Antirock front sway bar
- Currie CurrectLync steering
- Adjusted to toe-in to about 1/8" to 1/4"
- Centered the steering wheel by adjusting the drag link.
A few other notes:
- My Front LCAs are the same as factory (same as they came from Currie)
- My Front UCAs are about 1/4" to 1/2" longer than they came from Currie (which look to be the same length as factory). So at the most, the axle might be angled a little further forward than stock. This was match the pinion angle to the front drive shaft.
Thanks in advance.
