Currie Steering ends
Mrholland
Lifetime Supporting Member
Midwest
Is there an over the counter draglink and tie rod ends option for correctlync with aluminum tie rod?
Depends on the counter. But, if you are asking what parts have the same threads and will work in place of the Rock Jock parts, then the answer is none except the ones they build and sell. The problem is finding stuff that is as big in the thread department and still has the smallish tapered pins that work with the stock pitman and steering knuckle tapered holes. The threads in the tie rod are 22mm which is equivalent to 7/8" roughly which are typically the size of 3/4 and some 1 ton OEM steering link ends. None of that stuff has a small tapered pin.
