Has anyone else had this issue? The main bolt for the relocation bracket is not lining up. What’s the recommendation… should I wallow out the bracket hole to fit or the axle side bracket?
when I installed the bracket I put the large bolt in first, then anything that didn't line up I drilledHas anyone else had this issue? The main bolt for the relocation bracket is not lining up. What’s the recommendation… should I wallow out the bracket hole to fit or the axle side bracket?
Perseverance paid off once again. Well done!I got it! Little persuasion and a minute amount of grinding and wrenching, it’s snug now.
Good to know, will be installing mine soonI got it! Little persuasion and a minute amount of grinding and wrenching, it’s snug now.
Do you have access to a welder for the lower bit? (Same question to the OP)Good to know, will be installing mine soon
Nope, sure don't! I've got the bracket, little front lower CA mount skids, and my half upper door legs to fit my YJ half doors that I need welding for now haha. Hoping to trade some nice CO people some beer or cash or other labor to help me out with them when the time comesDo you have access to a welder for the lower bit? (Same question to the OP)
Let me know when, it won't be pretty but I can help on that one.Nope, sure don't! I've got the bracket, little front lower CA mount skids, and my half upper door legs to fit my YJ half doors that I need welding for now haha. Hoping to trade some nice CO people some beer or cash or other labor to help me out with them when the time comes
Thank you!!Let me know when, it won't be pretty but I can help on that one.
Haha I'm still waiting for my delivery. Hoping it comes by itself and doesn't wait for the backordered BL to be shipped together!@lBasket What bolt and nut did you use to mount the track bar to the relocation bracket?
You see that breather hose slipping off? How the hell am I supposed to keep mine on? It keeps doing that. I guess it’s snagging on something, but it’s annoyingHas anyone else had this issue? The main bolt for the relocation bracket is not lining up. What’s the recommendation… should I wallow out the bracket hole to fit or the axle side bracket?
That bolt that is circled was a pain in the ass and took me way to long to get it tightened. After f’in with it, I finally stuck a 1/2” wrench through the top, side ways to get it tightened
Can confirm…. Giant pain in the ass, damn near impossible to tighten. I went a bit rogue, I left the three smallest bolts in, backed out the main bolt and torqued the that top one. Then reinstalled the main one, and torqued everything up.
Also ended up kissing the brake line with a grinder. Its tight and I was rushing to finish, just a word of caution.
