Daily Driver, Go Where I Want To Build
Were you able to fall under the old superior replacement program?
Officially no. That ended several years ago. I still paid way more than I wanted to spend right now considering I just bought an unexpected locker, but the sting was lessened a bit.
Reactions: rasband
dam i knew you busted 1, but never saw mention of looking to purchase new. i mighta been able to save you a few $.
did you go for the 30 spline set-up?
was it you that i saw mentioned your fairlead is a little worn or not in the best shape, or wasn't right somehow?
Revolution US made shafts using the 1350 u-joint vs their Discovery import shaft using the factory 5-760 u-joint.
you change your mind? i thought i saw you got the discovery's. you reconsider and get the big 1's or i'm i losin it and mistaken.
