Love it!!
Love it!!
Are those Camaro Z/28 fender louvers in the hood of your Dad's CJ?Not sure if I posted this earlier. This is my dad's cj5 dash with all of his extras from years ago.View attachment 40992
Pontiac Grand AmAre those Camaro Z/28 fender louvers in the hood of your Dad's CJ?
The bags are doing just fine after two years. I don't use them much, but they do the job when needed. My dad has had these in his truck for much longer and used them far more then me. No problems there either.
I did not use the TJ kit and I did not follow AirLift's directions. I personally don't think they understand how our suspension works or how to tailor for a lifted TJ. AirLift recommends always keeping the bags at 3psi when not in use. They also tell you to cut or even remove the bump stop jounce. I disagree with this.
This is my recommendation...
Make sure the bump stops are correctly extended.
Measure the largest inside diameter of the coil. Measure the space between the axle pad and the bottom of the jounces. The deflated bags should be this size and fill the space. Close enough is probably good enough. Somewhere, I found a list of measurements. Then I called AL to confirm. Mine might be for a Toyota.
I run my bags empty when not in use. I also built in a bleed valve that can be locked open. I can hear it hiss while driving.
My thought is that I don't want the bags to add resistance to the up travel. I want them to start adding their support as soon they begin to inflate. And I want the jounces to do their job.
One thing I'll add is that the need for bags increases with softer spring rates. My Curries are long and light, so the sagging is exaggerated. Rubicon Express is short and heavy and will sink less if the same amount of weight is added to them.Thanks for the advice. I am still tweaking with my suspension, and will most likely do this soon.
I will check that out thanks for the tip!What you are describing is about how I ended up with bags in mine. I go back and forth between running empty and carrying or pulling a load.
Another build to study is Unlimited04's over on JeepForum. I got the air bag idea from him and much of my early suspension and my build philosophy comes from him.
A few months back I learned about these...
Select Increments DPE03065 Dash-Pods (without Speakers)
https://www.amazon.com/dp/B00T1AB28Y/?tag=wranglerorg-20
Mine arrived today and I installed them with my Polk DB521 speakers during lunch. I am now aware that I have front speakers! Much clearer sound with more volume. Before these I had foam baffles with adapter plates. I cut off the flange on the baffles to seal the speakers against the pods.
I've been considering these, I'm just unsure whether they're worth $80.
My current Polk sound system rocks! I just wonder if these would further improve it.
In my case, there was an improvement. Do you have any kind of enclosure around your Polks?
The rear Polks are enclosed because they are in the sound bar of course, but the front Polks have no enclosure at all.
