And finally, here is a solution to a problem of installing 12" travel shocks with Currie 4" springs. The way I built the mounts, the shocks are roughly 6" up 6" down from ride height. At full shock extension, the 22.6" Currie spring will come loose, potentially unseat from the axle side and can rotate to where the pigtail falls out of the lower spring seat pocket. This happened during the Moab trips.
An answer is this bit of cleverness. Take a small aluminum spacer and mill the inside to accept a small low rate coilover tender spring.
The spacer and tender spring assembly replaces the factory isolater.
With the Jeep weight on the springs, the spacer is just a spacer.
At full shock extension, the tender spring extends and puts about 25lbs of force onto the main spring to help keep it from knocking around and falling out of it's pocket.
[ATTACH
The spacer adds about an 1/8" to the front ride height. I'm ok with the small increase, so no adjustments will be made to account for that. My final up travel is about 6.25".
