Front and rear... You’re running 12” shocks?
Front and rear
Hell yeah. That’s going to be a real sweet setup!
And hopefully still understated, given what it is and eventually will be.
Are there supposed to be pictures with these posts?
More parts for the stretch and gas tank projects. The stretch will interfere with the emissions equipment in the rear corner. Today I got the emissions from an early TJ where everything is mounted on the inner fender.
The early emissions is arranged to lay sort of flat under the hood. And it has separate mounting brackets. Where my late TJ stuff in the rear corner is sort of vertical. But parts of it are mounted directly to the body. I can mix and match the early and late into a configuration that works for my new location.
Currently, the plan might be to stick it all here under the bed, opposite where the muffler should be. Keep in mind that the control arms on the frame will eventually be 6" further back.
To make that happen, I will need to rearrange, combine, and reconfigure the early and late emissions bits into something not as thick and also more compact.
Just the footwell. @hosejockey61 is letting me chop out a section from the one he broke to patch into mine.Are you stretching the body too, or just moving the footwell backward? ...
Still my daily. So I will have to get something else before the big work begins.... And...its still your daily, right? Going to pick up something to run around in during the week so the TJ can spend some time on jackstands?
there is a write up on pirate about loosing the charcoal can and rigging the rest up to function, too.
Miata’s are a fun alternative.
- Zedd
This, plus a another medium hardware case.
If anyone ever needed a truck or a van, it’s you.
sweet............ samurai axles should fit under that.
plenty of room for the wheels and no need for wider flares .....win win.
