In adherence to the current trend of DIY Savvy inspired tub rails, I have some 6061t6 bar stock.
Get it from Alreco? If not, I recommend checking them out for any future needs.
That's were I went. I don't go there often, but I have been going there for many years!![]()
Looking forward to seeing how you form them.
Did the Rangers and Explorers ever come with factory Warn hubs? I was told recently they were vacuum actuated and people would upgrade to the Warn kits.
Unless someone has found a way to get a smooth bend without steps, my plan is to make straight sticks that stop at the radius.
And not trim them in my shop......![]()
I need to route mine so Josh has his router and bit back. That will be done at home this time.
What spurred the change?
But what about all the stuff you have mounted under the hood!?
I need to figure that out!
I was surprised about how much room these keep. It may not be everything you have, but I bet much of it will be unchanged.
I'll need to study yours at some point along with the pics Blaine has been posting recently. The only extra things I have in there are the TCM, winch controller, and an extra PDC. The horns and trickle charger can easily go elsewhere.
