Did you send them off to get stickers?
Sent to mike h for paint
Did you keep the shock bodies and replace everything else?
To be more specific, the only thing that is new are the DSC reservoirs and the new tune. The shock body, shaft, top cap and bottom eye are my old shocks. The top cap has been redrilled and tapped for the larger hose.
The shocks are installed. The zipties are temporary so I can drive these things. The new DSC reservoirs are larger with different plumbing that requires that I build new mounts front and rear.
Also part of the refresh are these stainless steel cone spacers from RuffStuff.
I knew it was the stickers
To be more specific, the only thing that is new are the DSC reservoirs, hose, and the new tune. The shock body, shaft, top cap and bottom eye are my old shocks. The top cap has been redrilled and tapped for the larger hose.
The shocks are installed. The zipties are temporary so I can drive these things. The new DSC reservoirs are larger with different plumbing which requires that I build new mounts front and rear.
Don't forget the shaft and piston...those must be new too.
Now I'm confused...Does @jjvw have 7/8" shafts?
A nicer rear reservoir mount than I had before.
Wayne told me the hose orientation didn't matter as long as it wasn't on top.
We may have the same memory from several years ago when the DSC became a retrofit option for the 2.0. I remember the thought was that the 2.0 needed a .875" shaft with all the bits associated with that. Meaning the upgrade meant only the tubes were reused.
Does that clear the top of the tire at full articulation, JJ?
