Those come up as 3.3l caravan injectors. 20.9 lb at 3 bar(43.5psi)
Your stock blue tips are 22.5 lb at 3 bar
Stock 97-04 fuel pressure is 49psi so it makes comparing injectors tough.
The right ones for your 4.0l would have been 0280155784 injectors. 22.7lb at 3 bar
I'm not about to find out of those will work.
What was you afr gauge reading during the pop and crack?
AFR, when not jumping around, typically settles just below 15. This was before and after the injector swap. Whatever bad that was happening, was occurring elsewhere in the chaos of fuel ratios while driving. I have also been monitoring the O2 sensors during all of this and I can't make sense of anything other than that they are doing stuff.
