Make sure there are sufficient soft lines or ability to move between the pump, filter, manifold, etc. Any tubing that connects to things that are hard mounted.
A multi-port manifold block is very helpful for splitting the air to different points.
A check valve after the pump will help keep the system charged. I used a self bleeding check valve so that the York will discharge when not in use.
Make sure the clutch is connected to
ignition switched power. If not, the clutch's electro magnet will drain the battery if you forget to turn it off.
Thank you! I can see myself overlooking a few of these so that’s helps a ton.
