SOLD Dana 30 Overkill - Truss, Sleeves, Shafts etc.
sourbluff
Missouri
Price
875
Boonville MO 65233
After collecting majority of parts to build HP Dana 30 for my LJ I found a G2 Core Dana 44 housing at great price so am going in different direction. All parts are NIB but have been sitting in garage so may be some surface rust on bare metals such as truss or sleeves. All prices do not include shipping. Discounts if buy more than one item.
Also have HP30 housing that can be added but will not ship housing. Located 65233
Alloy 30 Spline Chromoly Axle Shafts https://www.quadratec.com/products/52400_515_07.htm $500
Artec Truss and brackets - package $230
Truss - will have upper passenger control arm tabs but no bushing https://www.artecindustries.com/ftruss-xj $115
Inner C Gussets - https://www.artecindustries.com/tjinnerc $65
UCF Lower Control Arm Bracket - 9/16 hole does not have slot/horseshoe for CAM bolt https://undercoverfab.com/link-susp...ts-for-jeep-tj-lj-xj-jk-no-cam-bolt-slot.html $70
Yukon Diff Cover - https://www.amazon.com/dp/B07HZHSVJS/?tag=wranglerorg-20 $105
Lube Locker - https://www.amazon.com/dp/B008RAAOJW/?tag=wranglerorg-20 $16
EVO TJ Magnum Axle Sleeve: Works on all Front Axles, Dana 30 and Dana 44 http://www.evomfg.com/EVO 44 Magnum Sealed Axle Sleeves, TJ $75
Do you have a price in mind for the HP Dana 30 housing? Tire kickin here but my current Dana 30 has to have oversized ball joints and I've been thinking about eventually swapping it.
TTT
Make me an offer on full package or individual parts.
Is the Dana 30 housing stripped (no ball joints, steering linkage, etc...)? Does it come with steering knuckles? Or is it literally just the housing and that's it.
No right answer, just want to be clear. Big thing (if I were to make an offer) is that it needs to not have wallowed out ball joint holes. Spicers were too small for my current Dana 30
Don’t know about right answer but will give you honest one. I’ve had it in shed for more than year and honestly don’t recall. Will be pulling everything out in next few weeks can look it over and take some pics then.
No sweat man. It doesn't have to look pretty if it's functional. I'd legit only be taking it off your hands solely to solve the problem of not being able to use normal Spicer ball joints on my current LP Dana 30. I'm running ebay specials in there now because they fit, and someday they'll go. When the time comes, there's a good chance I'll be looking to take it apart and swap it out so I don't have to use cheap parts for a job I don't want to do more than once.
FYI, will be heading to STL in September and passing through COMO on the way there and back. Keeping the housing on my radar if you never ended up selling it/anything
Everything except the truss can be used for TL/LJ Dana 30.
Will ship on your dime.
All offers considered
