Ive been building a Dana 44 to swap out my super 35 setup and was Getting ready to install the axle shafts and found that one of the shafts had twisted the splines
so I was going to buy some new shafts from Revolution but I’m not sure which to get, im pretty sure it’s not a stock TJ 44 because when I cut the brackets that the previous owner had on there I found some cut off leaf spring perches so I’m thinking it’s might be a XJ rear end but I’m not sure. Revolution has both options but they give no specications on axle shaft length or differences. Does anyone know the differences between the XJ and TJ rear axle and what shafts I need to order?
