Hi, I have an 97ish TJ 4.0 ... looks to have the dana 44 rear end. Burned up a bearing and need a new axel on the left side rear. Came across another complete Dana 44 rear end with disk breaks (versus drum that I have now). Ideally, would just swap the whole thing out and upgrade to disk breaks.
What do I need to look at to see if it will match (gear ratios, etc.)? Also, my jeep has a lift on it ... so just assume I can re-use the springs I have and what not and should slide right in???
Thanks!
Thanks!
