AndyG Because some other guys are perverts Lifetime Supporting Member Joined Jul 30, 2018 Messages 15,998 Location Alabama Nov 7, 2021 #1 Do you use the drain plug or pull the cover and is there any concern of leaving fluid in axles- I was told I over filled one once but never knew what I did, used 2 quarts, so I assumed I left fluid in. Thanks, Andy
JKP TJ Addict Joined Aug 20, 2020 Messages 1,530 Location Warner Robins GA Nov 7, 2021 #2 Unless I want to inspect or clean out the diff, I use the plugs. Fill it till it comes out the fill hole. If your pinion is rotated up, you may need to jack the rear up or park the back end on an incline to get the full amount in. Reactions: AndyG
