Helping a friend with finding out where to go next.
He has dana 44 HP (ford)
with calipers from 72 chevy 1/2 ton.
outer axle IFS bronco 1980-1996
f150 1/2 ton " "
outer spindle 1980-1992 ford bronco spicer # 707178x
GM flat top knuckles
GM solid flat plate caliper mount1973-1976
Problem is with rotor and calipers not able to be mounted in place he cannot get calipers on.
He did cut the rotors down but cannot cut down anymore.
Someone said cut the face of the shoe down but not the right way to do it.
He purchased the axle all set up but did not have rotors and calipers.
Has anyone heard of this setup of parts and what would he need to get it fitted with brake components
Thank you
f150 1/2 ton " "
Thank you
