Dash fuse panel
blewis8784
TX
I wired in some new LEDs and the hot wire came loose from the kremp and grounded out when I plugged into the left side of the dash panel.. that entire column has burned out but the rest of the columns work perfectly.. would I have to replace the entire fuse panel or is their a relay connected to that box somewhere else? Any help is very much appreciated!!
I’m confused. What LEDs were you wiring in? LEDs for the gauge cluster? Those don’t need to be wired in, they plug and play.
I must be missing something.
And want columns are you talking about? The way your post is worded is very confusing.
Just some 4inch round lights that site at the bottom on my light bar mounts
I think I understand.
Are you using a fuse tap behind the glovebox?
If it wasn't wired correctly, you may have blown a fuse or even a relay in the PDC under the hood. Open the hood and open the fuse box on the passenger fender and start checking any of those fuses that go to anything in the glovebox
I will as soon as the rain stops might be tomorrow. I was sure hoping there is a relay blown.. i looked in there and didn't see anything labeled to gk into the cab.
