I bought a TJ build 9/98, I'm guessing its MY 1999? 4.0 5 speed. Been going through it and fixing all the small issues.
It has an aftermarket stereo and the PO installed a new headlight switch. I put a new ignition switch in it. The heater blower switch doesnt work on High.
I found that if I have the stereo on and turn on the headlights, stereo turns off. Also if I have the stereo on and crank it up, eventually the odometer will blink when the "bass" hits, and if I turn the volume up more, itll shut off the stereo. I figured bad ground. Also to note, when the headlights were on the dash dimmer lights worked fine.
I found the stereo ground behind the dash and connected it to the back of the stereo. Now I can use both headlights and stereo at the same time and I can crank the volume without having the odo blink or shutting the stereo off. Now however the dash cluster lights arent working. I found the 10amp dash light fuse behind the glovebox blown. It blows every time I use the headlight switch, both marker lights (1st click) and headlights (2nd click).
Any ideas?
Any ideas?
