Thank you. It's plain to see that they are just as crappy as Wizard. They tried to tell me that no one had ever complained and the radiators fit perfectly based on the 1000's they have out there. We had to do the same mods to the fan shroud top and bottom and the holes for the shroud didn't line up at all.I got my northern radiator installed today. The china junk vatozone radiator that was removed was leaking at the top tank. I had to modify both the fan shroud and the radiator to make it work. Wasn't really a big deal but I did have in in and out an extra time in making it fit. The Northern radiator is significantly bigger than stock and as @mrblaine (if you need any more pictures let me know) noted on TOS it doesn't fit well if you have an AC condenser in the way. Pictures below.
I don't need any more pictures, I do however, need a radiator company that doesn't have it's head up it's ass.
The holes didn't line up too bad on mine for the shroud. The lower left mounting hole didn't line up real well though (well at least one of them didn't), I had to remove one of the two lower bolts to drop the radiator in.
The holes drilled for the shroud were too big though so I used some of the trim clips (don't know what the hell they are called) and different bolts to attach the fan shroud. Then I had to notch the radiator shroud support to fit those. I could've used nuts and bolts or used bolts to make studs to mount the shroud but this seemed like the easier option.
We had to do the same but our shroud was a bit lower and we didn't space it out.Also had to space the shroud out a bit to keep from flexing it too much on the oversized tanks. And I trimmed the upper hose again to match up with the oversized tank better.
None of this was too complicated, but it would have been nice if it fit better. Have you tried a Be Cool radiator? They are pretty damn expensive, but it might be worth it if they are good enough. Then again I could've just ordered an OE radiator for $250 and been done with it for another 15 years. I'm hoping this one holds together for a while.
We had the same issue. The lower bolt holes to mount it to the grill shell are too far apart. It wouldn't take much to acquire a factory radiator and use that to get correct dimensions.
They supply hardware in the from of nuts and bolts but reaching down behind the flange to put a nut on is just dumb. FYI, that "trim clip" is called an extruded U nut long pattern. There are typically two lengths, long and short and that describes the distance in from the edge of the panel to the center of the hole. The way you notched yours would need super extra long which isn't made that I've ever seen.
Did you contact Northern and let them know that for the money you spent it should fit at least as well as an OEM?
Yep, forgot to mention that their hose necks are a bit undersize. Our spring clamps worked after the hoses warmed up a bit.And my lower radiator hose is still leaking a bit today. Looks like I'm going to need to put a real hose clamp on it. The spring one doesn't seem to be getting it done. I tried to get the spring clamp stretched out yesterday and it stopped it for a while but it looks like it was only a temporary fix.
A lot of people on this form hail the factory radiator however in my opinion should work as you described holding temp to t-stat temp (195) any thing over you are producing more heat then can desapateI haven't contacted them, but I plan to leave a fairly detailed review on amazon where I bought it ($275 shipped for reference w/ prime). I might shoot them an email with the same info.
I did notice on my way into work this morning that it seems to cool better than my previous radiators have. Both the stock (albeit old) and china junk replacement have held the needle on my gauge steadily at just into the "0" on 210. This one climbs to the same spot, then drops down to about an equal amount below the center line and repeats. Seems to cool in about 7-10 seconds to the point that the thermostat closes. Definitely has more cooling capacity IMO. Now hopefully it will last.
It might have 15 years ago? Cheap china junk I bought was clearly not up to snuff. I didn't buy the jeep from the dealership though so I can't say how it reacted when new. I also may have just been paying more attention to the temp after doing the 2nd radiator install.A lot of people on this form hail the factory radiator however in my opinion should work as you described holding temp to t-stat temp (195) any thing over you are producing more heat then can desapate
