Dianic’s 2005 Jeep Wrangler SE
Dianic
11
Greece
Well it’s been a few years that I have been wanting something to play with in the summers and prices kept crawling up for stock condition cars so I decided to jump straight into a restored and “puffed” boy. Found this last weekend and couldn’t resist. I think the closing argument was the interior. Here are some pics
Dianic
Dianic
11
Greece
You really can't imagine how much different it makes the 4 cylinders. It's like a whole new machine. What size tire are you running?
33s. The car has the 44 rear axel. I was thinking 4.56 r&p, but need to work on those calculators you guys have posted.
balfred
330
US
No way. 4.88 at a minimum, preferably 5.13. I run 4.88 with 31's and the same eng/trans combo as yours. Works awesome.
Agreed, I ran 4.88s with a 5 speed and 33s and there were times where I had wished I had gone 5.13s so I would say an auto should definitely go 5.13s if you live in hilly areas. If you live in flatland then that could make a difference on gear selection.
Dianic
Dianic
11
Greece
Based on the calculator I found here I get the below result. To maintain identical to factory ratio I should do 4.56. Going 4.88 will shorten up the gears too much? In a manual tranny how short does first gear get with 4.88?
@balfred did you wish you had a 5.13 while driving on the street as well? Or just off-roading?
Thanks guys
balfred
330
US
Thanks guys
I loved the 4.88s off road and yes, a 5.13 would have been a little better as I had a manual but I was referring to strictly on road opinions. I really dont think you can go wrong with either to be honest but if you ever thought of jumping up to 35s at any point, you would have the gears in place to do it as best as you can with 5.13s. My friend that does gears for his off road shop always tells customers to take what he recommends as the perfect gears for them right now and go one step lower because A) it's not going to kill you on the highway but might hurt a little bit over the recommended and B) it allows for a change in plans down the road because Jeep people are notorious for plans changing down the road and that set of 33s or 35s or whatever that you said you NEVER would go to, yeah you are eyeing them down and thinking hmm, maybe I should make that change
Rob5589
Certified video trained differential rebuilder
6,205
W Sacramento, Kalifornia
Thanks guys
Remember, you are no longer identical to factory. Your Jeep is taller, tires are wider and heavier, so you need more gear to keep up momentum. I have no issues with gearing being too low in any gear and I cruise along the hwy at 70 no problem. And that is on 31's while you have 33's.
Reactions: Don Ashcraft
Dianic
Dianic
11
Greece
Finally did my re gearing, went 4.88 and I absolutely love it. Found my 6th gear, was a useless option before. Now I ride in town in 3d gear and I am laughing! Car is absolutely back to normal. At 65 approx I am still under 3000 rpm I think. I have a speedo error which I need to fix. Went from under true speed to over true speed by about 12 kms per hour. So when I read 120kmh it’s really near 105-108. Haven’t gone on a highway to test longer. Will order that gear and have it sorted.
Will make a separate post, there isn’t much info on the 4cyl on your side of the pond.
Here are some pics from the process and a topless one from the summer!
