Install the new Bosch fuel pump after having 0 psi to the rail. Install the new pump and got the tank back in and now only have 35 to 40 PSI at the rail. Engine cranks and starts to fire and then stops. Also flashing check engine light. And engine code p0627 after extended cranking it.
Coil pack is new and Hitachi brand and NGK spark plugs.
Also have a new PCM from Wrangler fix.
Very frustrated was a PIA dropping the tank. Any other fuel regulator to check?
