Checked the search,kinda confused.I will be installing savvy taillights for future clearance needs,everything else is stock,do I need to buy a flasher,maybe this one( Novita LM470)thanks guys
yes and change the remaining incandescents to LEDOrdered savvy t/l,will be the only leds in my 2002,do I need to change flasher?
Thanks Jerry I’m getting reviews that this does a clicking noise after you stop? Have you had this problem?thanksFor 2001 and newer you'll need the below for the Savvy tail lights. I recommend against replacing all of the other incandescents with LEDs unless you want to have to do wiring and circuit modifications to get them working properly. Some will work OK as-is but not in the front turn signals and side markers. LED headlights work fine with no modifications needed.
i would just go with the LM470. It is for sure the proper fit for a 01-06 from Novita and nobody reports weird behavior from it. You can get it from parts stores locally too. The official numbers for TJs are 97-00 EP26 and 01-06 LM470. The Gold Coast will work on 01-06 but the weird clicking behavior would keep me away from it. I don’t know anyone that says they have that experience with the LM470.Thanks Jerry I’m getting reviews that this does a clicking noise after you stop? Have you had this problem?thanks
Not only after you stop but lots of times when you flip the turn signal off or it self cancels. Fairly annoying.Thanks Jerry I’m getting reviews that this does a clicking noise after you stop? Have you had this problem?thanks
Thanks,I guess I’ll try the novitaNot only after you stop but lots of times when you flip the turn signal off or it self cancels. Fairly annoying.
I have no experience with that one. All I know is the GCD has problems with that and not all do it.Thanks,I guess I’ll try the novita
So,ok I thought about the the round leds,don’t really care for how it dates the look.if you were to run the savvy’s what flasher options do I have to make it work best?thanks BlaineI have no experience with that one. All I know is the GCD has problems with that and not all do it.
The Savvy's are just a simple LED light like any other LED. They don't care what flasher blinks them. Try the LM470, it is known to work and doesn't have the reported extra blinks that the gold coast has. Has nothing to do with what tail lights you run other than the tail lights being LED and needing a different flasher over stock.So,ok I thought about the the round leds,don’t really care for how it dates the look.if you were to run the savvy’s what flasher options do I have to make it work best?thanks Blaine
Ok,got itThe Savvy's are just a simple LED light like any other LED. They don't care what flasher blinks them. Try the LM470, it is known to work and doesn't have the reported extra blinks that the gold coast has. Has nothing to do with what tail lights you run other than the tail lights being LED and needing a different flasher over stock.
I actually installed an EP26 LED but the photo I posted above with a different flasher p/n was downloaded right out of Savvy's installation instructions. I figured what Savvy showed would be safer than what I used since mine didn't match what was in the Savvy instructions. Maybe what I found is outdated, I don't know. Page two at https://images.carid.com/savvy-offroad/items/pdf/sav-btl-installation-instructions.pdfNot only after you stop but lots of times when you flip the turn signal off or it self cancels. Fairly annoying.
Interesting. Have not seen complaints with the 470 so that’s a first for me. Wonder if maybe yours is defective.I have the Novita LM470, it is comically erratic. It works 100% but it is always slightly off in timing, like listening to a 6 year old play Beethoven. It is obvious every time I use my signals that the timing between flashes is off. Totally irrelevant but somewhat irritating.
I don't mind it that much, I've read many similar stories so I haven't bought a new one.Wonder if maybe yours is defective.
We use the GCD versions and just live with being annoyed.So,ok I thought about the the round leds,don’t really care for how it dates the look.if you were to run the savvy’s what flasher options do I have to make it work best?thanks Blaine
