Just recently finished up my 4 inch suspension lift by Rough country, I know I’ll need an alignment but I also need my camber bolts adjusted I believe. I don’t know much about how the camber bolts work or how to adjust them, I had to put new ones in because I had to cut the old ones out when replacing lower control arms. There is a decent amount of vibration I’m guessing due to the pinion angle? I have the skid plate spacer installed, so my question is, is my problem the camber bolts needing adjustment? I wouldn’t think I need adjustable control arms or that’s what the kit would have came with.
Also, just curious how the Jeep will handle after I get 33x12.5 wheels on it, right now I have 30.5x9.5 and when I have drove it I feel sorta uneasy going around turns it hoping that the wider tires with help my center of gravity and make it feel less too heavy.
