I gave no back story as not to influence any answers .Are you having vibes now? The pinion does look a little high but I'm curious why you are asking? Give us back story but not too long of a back story please
You don’t have an SYE, so you don’t need to tilt the pinion up. Set it up like the bottom pic in this image.Is it possible to evaluate that from the picture? Please share what you think.
Is it possible for you to guide me on how to set it up like the bottom pic? I guess I would have to rotate the rear axle downward but is it possible to do that ?You don’t have an SYE, so you don’t need to tilt the pinion up. Set it up like the bottom pic in this image.
Adjustable arms would get it done properly, in my opinion...Ok just did a Google search and it seems I need adjustable rear control arms to do that ?
Wondering if I drop the transfer case say by 1inch if it would correct those angles?
Set your upper and lower arms to stock length. Drive the Jeep to test for vibes. Doubtful you’ll have any if 2” is the true amount of lift.Is it possible for you to guide me on how to set it up like the bottom pic? I guess I would have to rotate the rear axle downward but is it possible to do that ?
