I'm close to wanting to pull the trigger to get my TJ on 33's, lifted, locked and regeared. I toyed with the idea of 31s for a while but I think I will benefit from the extra clearance of 33's. Also toyed with the idea of an LJ but after test driving one, decided to keep my TJ.
To give some background, my Jeep is a 2001 TJ with 32RH 3 Speed on stock 3.07 gears. right now it is on a 2" teraflex coil lift with 30x9.5s, open open Dana 30/Dana 35. The Jeep will be used for off roading in the New England woods and also daily road travel. I want plenty of articulation and clearance while still keeping the Jeep somewhat nimble, and I do expect to see rocks from time to time. The Jeep will be my DD for at least a while. As far as money goes, this is way more than I ever considered spending on my TJ, so I do want to keep cost to a minimum but I have a fairly open budget to do it the right way.
Hoping y'all can "review" my research and work and make sure it all makes sense.
I'm stuck between a few options. to get the "easy stuff" out of the way first, I'm pretty sure I want:
4.10 re-gear
super 35 kit
front and rear ARB lockers
BFG KO2s 33x10.5. Going for 10.5 to keep weight down, help with on-road snow travel and keep me as skinny as possible.
MORyde hinge reinforcement (already have MORyde hinges, so just need to add reinforcement plate)
now with that out of the way, the part I'm debating more. I seem to have two options for lifts.
Option 1: I can buy the Zone 4.25" combo lift and be done with it. In fact, I like the idea that I can install this kit now as is with my Jeep, and ride it as is without BL til I get the other work done. I like the simplicity of the kit, that everything you need comes with it, and I can probably do install myself. and of course the price is very nice. no need for SYE or new driveshaft (see note below)
Option 2: I can piece together my own lift with parts I have seen recommended around the forum. sounds like this would likely be a 1.25" savvy BL, OME springs and 10mm spacers, and rancho shocks. I am guessing there are other things I'd need in this kit, such as a MML, but not entirely sure what they are. Would SYE and new driveshaft be needed for this?
Note: I am also considering a tummy tuck. Always wanted one but the work and money involved with one seems high and the more I read about it the more I get turned off by the idea... At the very least, I'm guessing I'd need an SYE and new driveshaft. Would rear shock relocation, adjustable UCAs, and some of the other stuff listed in this thread be absolutely necessary?
I've always been a Teraflex guy coming from the JK world but their pricing is just way too over the top for a TJ lift IMO, so I won't be considering any of their options.
Appreciate any thoughts you all have.
4.10 re-gear
super 35 kit
