Just so people know, Mopar CCC is mostly water with a bit of ammonia added as a mild detergent. If I need to clean my combustion chambers, I
very slowly trickle 12-16 ounces of plain water into the TB while keeping the engine rpms up. That generates mini-shock waves inside the combustion chambers which is what breaks up the carbon that is fouling everything. That is also precisely how the Mopar CCC works. The water method I described is in constant use by mechanics who take care of high performance engines that fouled up with carbon when they're not driven aggressively enough.
That water keeps combustion chambers clean was discovered during WWII after they started adding water injection to military aircraft engines for more power that the engines were also staying sparkling clean inside. Water injection is still used to this day in some aircraft engines.
