Does rear Antirock sway bar need a body lift to be installed?
Silverfox95
Fletcher
I have a 03 jeep Rubicon. I am looking to purchase the antirock rear sway bar and came across there install video. The video described a tj with body lift. I have looked and looked for another form or video showing if you could still install the antirock if you have no body lift. I have a 4 inch suspension lift myself. I was just making sure it could be done before ordering. Thanks.
Mobusaki
Pennsylvania
I don't think so, but I don't have one so someone who does will hopefully chime in. However, I think the consensus is that it's only the front Antirock that is worthwhile for a TJ, the factory rear swaybar is fine. You may just need extended swaybar links back there. I have the front Antirock arriving tomorrow and no plans for the rear based on what I've read here. Are you sure you need it?
Jerry Bransford
TJ Guru Moderator
Staff Member
Fleming Island Florida
For the rear I would continue running the OE factory antiswaybar. Except for a heavily modified TJ like Chris described above there's no real benefit over the OE rear antiswaybar that has a similar stiffness.
Reactions: Bill M.
Silverfox95
Silverfox95
Fletcher
I have a 9 inch rear
Silverfox95
Silverfox95
Fletcher
I have a 9 inch rearend with the possibility of a 4 link next year when I bought the jeep there was no brackets for the sway bar so I'm going with the antirock. I just wanted to know if it would work without the body lift.
Reactions: Wildman
Wildman
Staff Member
In the hills of WA
I can't tell you if it will work without a body lift. But good luck and let us know what you think once it is installed.
jjvw
quetzalcoatl created you
Colorado, USA
Absolutely not. A rear Antirock is only used for custom suspension setups such as a Savvy mid-arm, other 4-link triangulated rears, etc.
The Savvy mid arm and any other triangulated rear works perfectly fine with the factory rear sway bar. You did not need to remove yours
Chris
Administrator
Staff Member
Florence, AZ
Hmmm, I didn't know that. Makes me wonder why they removed it. They had a reason for it, I just can't recall. Of course why did that shop do anything the way they did :rolleyes:
jjvw
Colorado, USA
Your shop was dumb. ;)
Silverfox95
Silverfox95
Fletcher
Tell me about it.
Alright that savvy mid arm kits 2500 dollars for one and for to i have a project to build not sit here a bicker with yall i asked a simple question that could possibly help me and maybe some in the future so if yall gonna sit here and talk trash ill delete this form and look somewhere else just because I'm going a different direction with my build doesn't mean I'm wrong. So if you have something that would actually help add if not get off.
Reactions: Wildman
Chris
Administrator
Staff Member
Florence, AZ
And I gave you a simple answer. It is NOT needed, period.
Do you slap your kid when they spill their milk?
Now you've been banned. Take your negative attitude somewhere else.
BuildBreakRepeat
Occasional Genius
McKenzie Bridge, Oregon
Dude, we were saying @Chris shop that did his work was dumb, no one was trashing your build. Oh well, bye bye.
jjvw
Colorado, USA
You are very confused about what is going on.
Reactions: Wildman
