Does rear Antirock sway bar need a body lift to be installed?
Scott313a
san diego
Is there a question associated with that?
The topic of this thread is, does a tj need a body lift for the rear antilock. I read one answer of, no. my tj is on the lift now, and there’s no way there’s enough room for the bar that goes across. my stock body mounts are worn but i’ll need to lift the body more than stock. has anyone that answered actually installed the rear onto a tj? thanks.
Reactions: bty34
Scott313a
san diego
Alex01
Itching For Some Rocks
Martinez, CA, USA
You may just need to drop the tank in order to get the bar in.... mine was a pita even with a BL so I dropped the tank a bit and it fit just fine. For reference I also have a savvy gas tank skid so even though I have a BL the tank is raised from the stock height.
Reactions: Jerry Bransford
Wildman
Staff Member
In the hills of WA
From the RockJock website:
Notes:
  • Body Lift - Ideally, this kit installs easiest on vehicles with a 1 in. body lift. It can be used without a body lift, but some minor pinch weld trimming underneath the back of the body tub is mandatory. Additionally, due to the age of TJ & LJ vehicles, we see a lot of the rubber body pucks have deteriorated with time, making the non-body lift installation that much more difficult – but it is possible.
Have you trimmed like it says in the instructions?
jeepin247us
Tx
Trying to install this on my 02' I will need a body lift to clear the rear fender on the driver side with the attached bracket and there is a flange on the passenger side that's in my torsion bar path
gogetter
Daily Driver
Omaha, NE
I encountered the same challenge with not having enough clearance above the gas tank to mount the Antirock torsion bar.
Have you considered installing it backwards (torsion bar near middle of vehicle and arms facing rearward)?
jeepin247us
Tx
Tell me about it :ROFLMAO:
This actually was the system I was looking for but couldn't seem to find it as a kit. I'm pretty sure this way will need a body lift also since the tub sits down inside the frame but I'll confirm later. Just disappointed in this kit thinking it would work without opening the body lift can of worms...
gogetter
Daily Driver
Omaha, NE
I used the original rear AntiRock kit (that I also could not install without a lift).
With the help of @Terry Tiemeyer it was very easy to place the torsion bar across the frame, weld the mounting brackets to the frame, and weld the tabs to the axle (Ford 10.5).
No body lift was needed to install in this fashion, and to my memory no additional cutting was required.
Attached are the best photos I could get without taking off a rear wheel. 🙂
