I have a 2000 Tj, the floor courtesy lights work but my dome light isn’t working. I replaced the dome light assembly and bulb and still nothing. Any ideas?
Found the correct one from another thread - it’s in the fuse box under the hood.I am watching this as well. I replaced the standard bulbs with LED, then after I put in the standard bulb back in, something blew up. I checked the fuse and it looks good ( will replace anyway), but lights don’t work at all, even with the steering wheel switch. Did I possibly blow another fuse somewhere else?
Which fuse is it?Found the correct one from another thread - it’s in the fuse box under the hood.
Bottom right, I believe it’s fuse 12 mine was red.Which fuse is it?
#26 on mine under the hood. Red 10ampWhich fuse is it?
If interested - this fuse #26 is only if the whole thing blows (no inside lights at all). If just for the doors off, it’s #4 behind the glove boxJust checked mine on my 2005 4.0l it was fuse 15 red 50 amp for IOD. (ignition off draw) I pulled it to turn off my dome lights when I pulled my doors before learning fuse 4 in the glovebox works just as well. Might be a different # for a 2000, but should be marked IOD.
