A few days ago I noticed my ignition was turning a little rough, and today it decided not to start my TJ. I could turn it all the way, but it wouldn't start the engine. All the lights came on, but no ignition. I popped out the ignition and was able to start it with a screwdriver to get home. This is much easier than you think. Once home I fiddled with the ignition...took it apart, cleaned and greased. Turned the pins that slide in it over, so the newer sides would help them turn smooth, and it was working nicely. Put it back in and it started with the key. Success I thought! Then I took the key out and the door chime was still going like the key was in the ignition. Well crap, now what? It's one of three things: Ignition still faulty, Actuator gone bad, or Ignition Switch went bad. Don't think it's the Ignition Switch or it wouldn't start the Jeep. Inside the actuator is a little pin, that when depressed by the ignition, causes the door chime. There is a hole in the ignition where this lives. I'm thinking it's not aligning properly, but there's really no other way to install it. Anyone ever encountered this? What was your fix?
