These seem to be pretty common on TJ's, so I taped off the crack , filled with black RTV silicone and tooled it semi smooth and pulled the tape .
Worked pretty good.
Worked pretty good.
Oh damn! That looks good! I have that same damn crack on my driver's side door, but just figured it was something to live with and get used to. I guess I may actually take a stab at fixing it now, although I have the khaki style interior.
Looks good! On mine I super glued it and as my panels are also black I took the fuzzy part of a roll of Velcro and put it on the top of the panel. Fits perfect as its the same dimensions as the panel.These seem to be pretty common on TJ's, so I taped off the crack , filled with black RTV silicone and tooled it semi smooth and pulled the tape .
Worked pretty good.
Show us a pic , trying to visualize . Thanks sir.Looks good! On mine I super glued it and as my panels are also black I took the fuzzy part of a roll of Velcro and put it on the top of the panel. Fits perfect as its the same dimensions as the panel.
Here goes a couple of pic of my cracked door panel fix.Show us a pic , trying to visualize . Thanks sir.
Oh cool, I see now .
Nothing worse than a crack that spreads.In all cases...make sure you guys are drilling a small hole at the end of the existing crack before you fill it. The hole will prevent the crack from spreading further.
