DrDmoney’s 2000 Jeep Wrangler Sport
Sweet machine! What front axle are you running? Have you upgraded the axle shafts at all or any other axle upgrades? I know you have regeared and added lockers, just wondering if all else is stock?
Reactions: DrDmoney
Thanks,
I’m running G2 Core 44’s at both ends, they have 30 spline chromoly axles in the front and 35 spline CM axles in the back
I have a Tera low 4:1 transfer case with Slip yoke eliminator and a short shaft conversion + Tom Woods Double Cardan Drive Shafts.
Thanks,
I’m running G2 Core 44’s at both ends, they have 30 spline chromoly axles in the front and 33 spline CM axles in the back
Awesome!
Here is a list of current mods:
2000 TJ Sport
4.0 Liter
G2 Core 44 front with 5.38’s, and ARB Air Locker, and 30 Spline CM Shafts.
G2 Core 44 rear with 5.38’s, ARB Air Locker, and 35 Spline CM Shafts.
Tera-Low 4:1
Short shaft
Tom Woods double Cardan DS
4 wheel disc brakes
Fox 2.0 w/remote reservoirs
Currie HD “Currectlync”
17 x 9 Bead locked ATX Slabs
35 x 12.50 x 17” BFG KM2’s
Banks Monster exhaust
GenRight Rear Bumper Plate
GenRight aluminum swing out tire carrier
GenRight aluminum Boulder winch guard front bumper modified to fit winch
Warn Zeon Platinum 10S W/relocated control pack under hood
Factor 55 Splicer
RE 4.5” Super Flex
Sun Performance Rocker Guards
J.W.Speaker LED Headlights
Grill mounted LED Turn and side marker lights
Rear 4” round “Mirage” Taillights
All lights have been converted to LED’s
Aluminum trail half doors
MCE Flat Fenders and rear flares
Custom hood louvers
Rock lights
Air actuated Swayloc Dual Rate sway bar
BeCool Aluminum Radiator
Electric Fan w/Shroud
Banks Ram Air
Optima Yellow Top
ARB Twin Air under hood mounted with relocated filters
HPS Hoses
Flowkooler water pump and t-stat
Rear LED Cube F-U lights custom mounted
Vernier Knob Hand Throttle
“Old Skool” gear shift and t-case shift knobs
Custom ashtray delete switch panel
Rugged Radios 25 watt WP dual band race radio A-Pillar mounted
Kenwood KDC BT Stereo in Quadratec secure mount
COBRA 75 WX ST W/4’ fire stick concealed console mount
GenRight Full Roll Cage w/removable harness bar and rear and side tie in bars.
Tuffy underseat security drawer
Smittybilt rear storage drawer
MasterCraft Baja RS seats
3” 5 point Impact Racing Harnesses
Smittybilt C-RES cargo net.
BESTOP Safari Top
HiLift Jack on custom roll bar mounts, not on display, inside, out of the way, protected, so it will work When I need it.
Drake fire extinguisher mount
DeWalt 1000 watt inverter w/40amp fused circuit at rear
Kolpin 4 gallon fuel can inside mount
2000 TJ Sport
4.0 Liter
Tera-Low 4:1
Short shaft
4 wheel disc brakes
Factor 55 Splicer
RE 4.5” Super Flex
Custom hood louvers
Rock lights
Banks Ram Air
Optima Yellow Top
HPS Hoses
BESTOP Safari Top
DeWalt 1500 watt inverter w/40amp fused circuit at rear
Seems like a mild build. Do you plan on modifying it soon? :ROFLMAO:
Reactions: Nickgsjeep
80906
80907
80908
80909
80910
80911
80912
Great pictures ! I have family in Pollock pines that I visit regularly and I’m always jealous of them living so close to so many options of trails
Reactions: DrDmoney
We used to live in Georgetown at about the same elevation as Pollock, got tired of the drive and the snow.
More pics of mods.
Flush mounted LED tail lights
Relocated LED turn signal/parking lights'
Aluminum radiator w/electric fan
Silicone hoses
200amp alternator
Winch control pack relocated in engine bay
81561
81562
81563
81564
81565
81566
81567
Reactions: TJ Starting
