I know you would, I’ve been looking at the TR flip as a possible before the Con trip that and swapping the coil perchesTell me when an where and I'll be there.
Relocating the rear so they are straight? I haven't heard of swapping.I know you would, I’ve been looking at the TR flip as a possible before the Con trip that an swapping the coil perches
trac bar bracket forces you to cut the passenger side down, but if you swap you don’t have to.Relocating the rear so they are straight? I haven't heard of swapping.
Flip the driver to passenger and vise versa and no need to “cut down”.trac bar bracket forces you to cut the passenger side down, but if you swap you don’t have to.
CorrectFlip the driver to passenger and vise versa and no need to “cut down”.
Sounds like it’d be easier to be one of those guys then make excuses to not be.Those guys with no trac bar don’t have to worry about stuff like that.
I didn't know that.trac bar bracket forces you to cut the passenger side down, but if you swap you don’t have to.
I might take you up on that the Core 44 sway bar mounts are a little different that the Dana and there is just about enough room to clear with some grinding.I didn't know that.
If you want to flip I have an extra insert in the mail that I won't be using. The one I bought took 2 weeks to ship and I got another one while waiting. Its a TMR I can toss it in the mail once it shows up. The one I'm using is go-fer-it offroad.
I'll pm you when it arrives, ups says friday. I have no use for it so even if it sits in your to-do pile it's better than in my garage.I might take you up on that the Core 44 sway bar mounts are a little different that the Dana and there is just about enough room to clear with some grinding.
Looks great!!Looked at it one too many times I just need to finish welding.
View attachment 187087View attachment 187088View attachment 187089View attachment 187090View attachment 187091
I was going to go wheeling with TimmyYJ, maybe a good thing i stayed home.Looks great!!
LOL, I just sent that to him. Best thing for a bruised ego...more beatings.
The spring clears the bolt head, it wouldn’t if I ran it the other direction. It doesn’t look like there will be any interference anywhere else.Thanks for the pics. Was trying to figure out how to do that and still run a rear TB. Do you think you'll get any interference with the spring and the TB frame mount bolt head?
I only lost about 1/4”.Did your height change at all?
