Haven’t thought about it much, you want them?Jeep candy! What are you going to do with your old ones?
Yeah not this weekend unfortunately starting a remodel project, but thanks for the tip.Nice... you should have some fun this weekend. Don't forget to lather them up in anti seize.
20 year old RE armsNo, I don't need them. I have a full set of MC arms on my junk. I don't even remember what you were running prior.
Must be something in the water here in Northern California I suppose.Yes, anti-seize is your friend. I made the mistake of not putting any on mine and now my front uppers are seized. Now I have someone else to make fun of for running those silly MC joints, lol! The JJ fan boys are going to flame you brah!
Let them, I’ll use my HiLift when I change them and try to work my winch thimble eye into the photo too.Yes, anti-seize is your friend. I made the mistake of not putting any on mine and now my front uppers are seized. Now I have someone else to make fun of for running those silly MC joints, lol! The JJ fan boys are going to flame you brah!
That’s so true, I still haven’t gotten it all of my wheels from the beadlock bolts.
I’m still holding my water pump, electric fan, and 16 yr old aluminum radiator cards too.Dang brah! Going full retard I see, lol! I better go get a bigger stick so I can poke the bear too!
Had a little bit of time while I was Traeger-ing, straightened my rear lower mounts and installed rear LCA’sView attachment 103174
my old RE arms are about the same weight, maybe lighter even. the problem is my 4.5" Re's aren't as strong and more susceptible to bending. one has been hammered a number of times (passenger side) plus the new arms are double adjustable which allows you to make adjustments in place (pinion angle, four wheel alignment, and such) as for skid plates my skid plate is 3/8" thick and lighter than the factory one it replaced. steel bends easier than aluminum for the same weight. I had my RE 4.5" lift since February of 2000 and it was beat up, I've rebuilt the flex joints 5 or 6 times and replaced the clevite bushings twice. the ends on these are where the weight is, just like the Johnny Joints. If you dont already have the "RE clunk" you will eventually.Out of curiosity, did you do a weight comparison between your old RE parts and the new aluminum control arms? I noticed you have a massive aluminum fetish (lol, you admitted it already) but I’m still nervous about using aluminum on my Jeep, especially skid plates that I end up dragging on rocks. I also ask because sometimes weight differences seem to get blown out of proportion; for example, I always heard beadlocks are so much heavier but when I weighed my old steel wheels with 35” tires they were 92lbs each, and the beadlocks were 101 lbs each, only 9 lbs more with tires that weighed exactly the same (64 lbs).
thats too bad, how did your jeep do on the Con? your build is similar to my original less the 4:1 lowrangeThanks for the reply. I will have to come up and drool all over your Jeep one day, I have the same lift but not nearly as many trick parts. I still consider myself a novice in the sport and have only done the Rubicon once, so definitely learning as much as I can. Going back to do that trail again at the end of August, unfortunately can't join the forum trip in September.
