I swapped out my Dana 35 for a Dana 44 yesterday. I have a 98 Sport 4.0 with a manual and a 2 inch lift. The Dana 44 came from a 05 TJ. When I reinstalled the driveshaft I had to put effort in pushing the slip joint in enough to get the u-joint end of the shaft over the pinion flange ears. Once the u-joints were seated that end of the driveshaft moved rearward about 1/2 inch. This was with the Jeep on the ground and weight on the axle. I was wondering if there is a significant rear driveshaft length difference for a TJ with a Dana 35 vs Dana 44?
Thanks,
Dan
Thanks,
Dan
