The 2001 Sport 4.0L that I purchased 14 months ago had OEM 20 year old sagging springs and decided to restore the factory ride height plus a little more.
The before ride height measuring from the floor to the fender flare on a level surface was 33.75” front and 35” rear and after 35.5”/37.25”. The springs are ProComp 2” which were economical and available; also replaced all four bump stops and the front rubber spring isolators.
Here is the interesting occurrence after the lift install; the Jeep is receiving driveline vibes, but after folding the rear seat down and and filling the gas tank the vibes are 85% gone.
I understand that the transfer of weight in the rear changes the driveshaft angles which reduces vibrations and could reduce a little more as the lift settles.
The suspension is stock other than Bilstein shocks.
Thoughts and opinions are welcome.
