Driveline wobble with lift
RyanMkTJ
Oregon
Hey all, I’m planning to do a budget 2 inch RC spacer lift on my 98’. I’ve read lots of mixed reviews about whether this will give me driveline vibrations or not. Curious what people have experienced. Will a 2 inch suspension only lift cause an unpleasant driving experience or will things feel as normally bumpy and wobble as they usually do?
Chris
Administrator
Staff Member
Florence, AZ
With a 2" spacer lift you will likely need to drop your transfer case slightly if you experience vibrations. Other than that you'll want new shocks as well for the added lift height.
Reactions: RyanMkTJ
RyanMkTJ
RyanMkTJ
Oregon
The kit comes with new shocks so I will have those. Adding a T case kit or using washers seems easy enough. Any chance I’ll have no vibration or is that just wishful thinking?
OldBuzzard
San Denver, Colofornia
Every Jeep is a little different, hence the mixed reviews you saw.
Shocks are one of the biggest contributors to how it will ride. What shocks come with the kit you're looking at?
Chris
Administrator
Staff Member
Florence, AZ
There’s a chance you’ll have no vibration. You may get lucky.
