crackedcornish
Sadly, I saw nothing in the tailgate section for TJs...
did you see the pics of the LJ with the CJ tailgate? well if people can use a CJ tailgate on a LJ, you can use one on a TJ
I did not. I'll have to go back and take another gander at it. Thank you!did you see the pics of the LJ with the CJ tailgate? well if people can use a CJ tailgate on a LJ, you can use one on a TJ
Can't seem to open it or locate the item when I go in a different route...Just throwing it out there: have you thought of https://www.amazon.com/dp/B002Y2YIBO/?tag=wranglerorg-20 storage bin, @Squatch? $50 cheaper!
Don't know the measurement differences, though, and it's just too damn cold and snowy here in Chicagoland to go out and measure!
from page #2 of this threadI did not. I'll have to go back and take another gander at it. Thank you!
Oops! Yep, I saw that!
Bwahahahaha!!! You're quite the joker, aren't you, @jchadscud?GoFundMe for Squatch. Seeking $20-40 for a nice card table. Foldable legs required, leather table surface optional, must be able to setup behind a TJ. Snacks required.
Okay, that one worked. Thanks! That looks functional, but the other is different enough that it kind of has a cool factor, as well. In all likelihood, I'll not end up with either one. For that amount of money, there are lots of other things that would take priority.The heck? The UBB code was screwy. Weird! It worked earlier.
Anyway, here's the link I tried to share (edited the original, too, just in case).
It was just a picture I found on Google to get a good example of the stock flare on the CJ.Did I miss the pic, or did you add it later? Because I'm liking that one a lot!!! Any more pics of it?
Besttop used to offer a set that looked like YJ flares, but wider. I've only seen a couple of them, but I'd love to get a set. Sadly, they're not available anymore.That looks great! I also love the radiused wheel wells. Speaking strictly on the aesthetics of the TJ's rear flares, it has always bugged me that the rear flare is squared-off, whereas the radius of the fender/tub is rounded.
