With the ARH headers (see here:
https://americanracingheaders.com/collections/jeep/products/jeep-1998-2006-tj-4-0l-long-system) Golen was putting down an extra 20whp on a stock 4.0 with no tuning. With tuning I was told you could expect another 10whp more potentially.
That's with headers alone. Open up the head more (i.e. bigger valves, hotter cam, etc.), and I suspect you could add another 30-50whp depending.
The stroker would of course add even bigger numbers with the forged internals, E85, etc.
A stock 4.0 at sea level regularly puts down around 150whp on a conservative dyno. A 4.6 stroker with forged internals, head work, a hot cam, long tube headers, and tuning should probably put down an additional 100-125whp in all reality. That's really damn good though!
Add forced induction and then you're talking about the potential for 400whp on the same engine.
Golen has a supercharged 4.6 stroker that is built to the max. I believe it's putting out 500+ hp at the crank!
