Installed new ball joints and when I removed my axles, there was quite a bit of differential fluid that leaked out of the axle tubes. Afterwards, I've had a slow leak from the tubes, but only after a drive.
My jeep also has those dumb outer axle seals. My theory [hope] is that those outer seals are holding the fluid in the tubes except when I'm driving, and that maybe my inner seals are fine.
Is there a way to easily test the inner seals to verify if they're leaking or not?
