I've searched but not found an existing thread with anyone experiencing the same issue as me... Hopefully I've not overlooked it.
My 03 TJ X has a detroit in the rear Dana 35 with super 35 axles and 4.56 gears. Generally behaves as expected, occasional noise on tight turns with non-neutral throttle input, a clank when taking off in first after reversing once in a blue moon, etc.
However, at ~55mph+ it seems like it's unlocking, on average once every few miles for a split second. When driving above 55, I often hear a popping sound from the rear end and the jeep kind of jerks to one side, generally the drivers side like its unlocking and only transferring power to the passenger rear wheel for a split second. The jerk isn't violent, feels more like a gust of wind. Tire tread & pressure is even, same sized tires all around, weight transfer is even, etc.
Once more, Harmon Four Wheel Drive in Tulsa (seems to be a reputable shop) recently troubleshot the issue and couldn't find any reason for this behavior. They tore the locker apart and reinstalled with new bearings and seals while everything was apart and setup the rear end again. Their only suggestion is to go to something selectable or LSD. I've never heard of a properly functioning Detroit, lunchbox, TrueTrac, etc. behaving this way.
Any thoughts?
Any thoughts?
