What can someone tell me about the real world use of an Eaton Elocker? Do they work well? Reliable? Do they break easily?
I chose the Eaton over the ARB because of my past experiences with pneumatics and electric actuators. I simply prefer electric actuation.
Yep only if you pay attention to either old wive's tales or if the ARB was installed by someone who didn't know what they were doing is there any reason to fear air lockers.Locker on our F600 at work was air. It was reliable.
I only said anything because you questioned the reliability of the ARB's use of air for actuation. My point was that if the ARB's air actuator system wasn't reliable enough to survive North America's arguably toughest long distance event, the overwhelming majority of its serious competitors wouldn't be running them.Without question the ARB is tougher than anything else. But I'll never be competing at KOH or anything close. Like I said previously, my choice is based on my professional experience with pneumatic over electronic. Not knocking ARB just preference
I know what you're saying for sure.....but Longevity is my issue with ANY pneumatics
None of the KOH guys will leave those diffs unopened for years at a time. Just like the engines of drag racers they will be torn down, inspected and maintained thoroughly and frequently. Air lines replaced, parts and fittings inspected closely.
That's racing
We could ALL benefit from aluminum roller rocker heads...yet we're ALL running cast iron in our 4.0s
Don't believe the crap about ARB's. Little of it comes from real world experience.Eaton has been around forever. Eaton actually cares about addressing issues which is a good thing.
I've actually heard from some that ARBs aren't everything they're cracked up to be. Either way, I guarantee you that an Eaton e-Locker is not a bad differential. Sure, there's stories out there about 'issues', but the same can be said for just about anything, especially if you beat the piss out of it.
How much longevity do you expect? I've never had an air issue I didn't create and the only issue I've had with ARB o-rings were ones where I split the housing and the prying from the axle took out the o-rings. The pneumatics in the ARB are at least as reliable as any aspect of any system on a TJ.I know what you're saying for sure.....but Longevity is my issue with ANY pneumatics
That's racing
Eaton makes a solid locker. As a comparison though, the little old school ARB compressor I have in my rig has been in there longer than OX has been in business. I see few locker failures with the exception of factory lockers that aren't the fault of the driver doing something he shouldn't have been on a less than stellar install.
In my personal stable I have twin ARB's in the crawler, TJM air in a rear 44, JK 44 front, HP 30 ARB with a Rubi 44, 2 33 spline 44 ARB's on the shelf, and a Detroit Trutrac beside them. I'm not a locker snob and I'll run most things with a good rep.
If I build another set of axles, the rear will have an ARB or E-Locker and the front will be full case Detroit.
