Hey guys,
I’ve exhausted a friends and my own knowledge of the TJ’s electrical system and can’t seem to find the fix. I have searched but I can’t seem to find my specific issue. I’ve checked all the fuses and relays under the hood and in the glove box, and the relay under the steering wheel (that I found out is for the blinkers).
Everything started off with an engine light, which ended up being the code for the TPS... which I unplugged, cleaned and replugged in and the code cleared after 5 or so miles (so i believe it is unrelated). After I decided to spray off the engine compartment using only normal water hose pressure, and trying to stay away from electronics. I parked the jeep in the garage and the next day surprise...
Things that don’t work:
Radio
Cluster gauges
Under hood light
Dome/footwell lights
Things that DO work:
It runs and drive as normal
Warning lights and blinker indicator on gauge cluster
Backlighting of gauge cluster
Headlights
Tail lights
Blinkers
PS... what does the one relay in the glove compartment do?
Radio
Cluster gauges
Under hood light
Headlights
Tail lights
Blinkers
