Need help!, 2004 TJ. It appears I have an electrical short causing my break lines to act as the grounding source which turned them red, yes red glowing hot, setting fire to the plastic stand-offs. When this occurred I a got a check gauge light, I saw my alternator gauge go to 9 volts, when I pulled over and shut off the engine I popped the hood to find a fire under my master cylinder where the four break lines pass through the plastic stand-off. The battery cables and battery were super hot and battery discharged completely within 45 second of turning off engine.
I can not find any melted wires, or smelled any wires burning. I have good grounding wires connected from batter to engine block and fire-wall. I have not found any wires grounding to the brake lines anywhere under the jeep.
Where should I go from here?
PS, Luckily I broke down just down the street from where I live and got another Jeep to pull me home, saved a little face.
Thanks everyone for your help.
ArmyMohawk269
ArmyMohawk269
